Hi everyone,
I want to run some sort of idle control setup on my AGG motor right now.
There are two ways, either I hook up the stepper motor on the MP9 and run it, or I find an idle control valve to hook it up to.
Have any of you successfully got a stepper motor(https://www.oyostepper.es/) up and running ? If so, would you be willing to provide some info on how to get it up and running?
The reason I am doing this is that it will help a lot with cold start idle and when you leave the car parked next to the robot at night when it is raining and the load on the alternator (headlights, windshield wipers and possibly fan) is pretty high.
I want to start the car in the morning and let the idle go up to 1100rpm and then settle down to 950rpm once the engine is up to temperature, basically like a standard car.
I am running an XMS 4C-4A management system,
Thanks a lot for your advice.
