Different fan angles 532nm green line laser alignment
What is an easy job to make highly clear and fine enough line measurement? It might be processing at various work distances. The real use of 532nm green line laser alignment enables highly visible green laser light emission from a middle wavelength of 532nm green DPSS laser. It always makes high precision line projection within long extending distance and high lighting effectively.
After it is connecting with external DC power supply, green laser module makes constant green laser beam and green line projection. It enables highly precise and fine green line projection from a qualified glass coated lens or separate crystal lens. Within wide fan angles of 10 to 110 degree, after strict laser beam stability and aging preventing test up to 24 hours, it always brings users high stability line projection for all precise device manufacturing works perfectly.
Applications: stone, wood, metal, steel and garment processing, laser cutting, sand milling, lumber machine and science
