Professional Introduction of Economy Red Dot Laser Alignment
In order to get high stability dot measurement at different work distances, not simply adopting a red laser pointer, it would be much more efficient job for users to try economy red dot laser alignment. It is making good use of a 650nm red laser diode and cooling system. In occasion that it get constant power source supply and correct use of output power, only after its proper installation onto any other industrial machine or device, this direct diode emission made 650nm red laser module just assures high quality red laser light emission, and highly clear red reference dot projection at various work distances.
Economy 650nm Red Dot Projecting Laser Alignment
Comparing with a simple red laser pointer, not simply limited for temporary dot positioning works, this economy red dot laser alignment is working well with continuous red laser beam and red dot projection from beam aperture. It is employing an import 650nm red laser diode within 5mW to 100mW. When it gets long developing history and mature laser diode tech, after getting mass production, this finished product of 650nm red laser module is always getting highly stable and reliable red reference dot projection, and quite low production cost for all precise device manufacturing work fields.
From the very beginning design of economy red dot laser alignment, in order to get clear and accurate enough dot measurement at various work distances, it is adopting qualified glass coated lens. Within wide range output power of 5mW to 100mW, when it is projecting high transmittance red laser light from beam aperture, it is also making highly clear red reference dot projection for a lot of application fields, including laser marking, laser engraving, drilling system and other scientific research work etc.
Being made with extending electric wires for both economy red dot laser alignment and DC power supply, within the maximum installed distance of 3 meters, this economy red dot laser alignment just makes easy and convenient red dot projection onto any vertical or horizontal surface. For the most important of all, after its easy screw of adjustable focus optic lens and immediate red laser light concentration, this red alignment laser gets increasing accuracy red dot projection within the maximum work distance of 25 meters. When users are aware of any thermal energy hurt and powerful red laser radiation, after proper selecting of 650nm wavelength preventing laser safety goggles, it always makes easy and highly clear dot measurement in all occasions perfectly.
 Share
